G706 Fuel filter
plowhand
Is there a replacement or retro fit for the sediment
bowl with filter on the Diesel engine always a pain to
change or a user friendly solution for that
bolt/screw?...thanks in advance.
(quoted from post at 09:13:21 11/25/18) Is there a replacement or retro fit for the sediment
mine has an old change over to a John Deere rectangular style glass filter. Have seen several G705/706 with the same set up. Sorry I do not have a picture handy.
Plowhand,
Did you get your filter problem figured out? I have MM602D with probably the same setup as you and mine too is a pain. 602 has two filters, first with metal can and second with glass bowl, same as yours? Never does not leak. I am going to change over to something more modern and if you have not solved will let you know what I do.
Let me know!
Gary
(quoted from post at 20:04:36 12/08/18) Plowhand,
Let me know!
Gary
Any update on your tractor?
