445 and UO disc out for a trial run
Alan K
Took the 445 and the UO disc out to check the governor and set the carburetor. Seems to be working ok now.
I believe I sold you some weight boxes for one years ago. They do pull a little harder than one with regular bearings.
Looking good Alan. I remember seeing a few of those little yellow disks go through the sales pavilion in Renville in the early '80s. Wish I had bought one. I don't see them around here any more. They are different with the wheel on the inside of the arm. Brian
Thanks Brian. Ive only seen 2 of these discs around here. Usually with the wood bearings they were used until all the metal was wore off of the housings long after the bearings were gone. They are an interesting disc, that is for sure.
