MM M5 Oil seal and dust cap for the PTO
lenray
Can a fella buy a new dust cap and the oil seal for the PTO on a MM M5 tractor???
I can't get the old dust cap off and it is leaking oil from that area. Probably never been off and will damage removing it. Thanks for any help.... len in michigan
There are a lot of them running around without the dust cap. Usually get wrecked when removing. Sometimes you can gently work them out and straighten them to reuse.
Drill a small hole or two in it and thread screws into it to pull it out. Do the same with the seal. If the dust shield is not too damaged, you can likely reuse it by plugging 5he holes.
