FarmallPaul
Hi All- I'm replacing a broken manifold on a model M5 that I just bought and as I was cleaning up the ports on the heads, I noticed that the front of the front exhaust port and the back of the back exhaust port had burned thru the gaskets. I don't know any history, but this ole girl's been apart and back together a few times! I put a straight edge against the ports and it looks like there is about 0.080" gap from front to back. The ports are true for each head, it's just that the heads aren't in line with each other. I have gathered from other posts here that the proper way to mount the manifold is to torque it down with the head bolts loose and then torque the head bolts down. My problem is, is this OK to do without tearing into it and replacing the head gaskets? Would it be OK to just loosen the head bolts, install the manifold and then retorque the heads? I'm not working on a show tractor or anything here, just trying to get back to feeding hay to the cows. Any input will be appreciated! Thanks-
