wiring schematic
I dont know if this is specific to your tractor, but as it says on the diagram, MM letter series tractors. This diagram seems to be correct for my "50 ZA.
Thanks for the drawing. That should give me a good starting point for rewiring this tractor. By the way do you Know if a 45 RTU was neg. or pos. ground. The tractor has a three position keyed switch, I'm assuming off/on/lights like in the schematic. Do you know if they origanaly had a key switch or a switch with just a knob? Thanks again Dale L.
That's right diagram for 6-volt un-changed system. Positive ground on all 6-volt MM's, even some 12 until constellation series in mid 50's. Notice that in diagram. AND, even coil is plus to dist., opposite of what you may be used to. Will still work with neg ground, ammeter will read backwards and gen may have issues if incorrect.
All Of the Molines I have seen from this era used a large round lever type switch.I saved this thread from the forum showing both sides of the installed switch on a restoration in progress, this type of switch is available from many vendors, including JD, Stieners, Napa, ect. If your interested, Moline parts.com has nice wireing harness' pretty reasonable as well, Hope this helps...tom
Thread on this subject
My '45 R has a push/pull switch for the ignition and a separate push/pull switch for the lights. I don't think the lever type ignition/light switch came along till a couple years later.
Rich, I think you are right. I called Motec Engineering for a wiring harness and Matt thought this tractor had push pull switches like you say.I went out and looked at the instrument panel on the tractor and you can see the old holes where the lite and mag switches used to be.The instrument panel is layed out different than the one on the link that sunsettractor has. They are different tractors thow.Is the mag switch on the left side or on the bottom? I'll have to try and find an original panel or take out the key switch and weld up the hole. Should be a nice winter project. Thanks for all the info, Dale
