Replacement Fuel Sender and Quantity Guage
Any suggestions for what to repace the sending unit and gauge on the 14 gallon tank that's used on the 445 Utility or Big Mo 500? I still have the tractor wired with the positive ground. Thanks for any help?
John
In many auto/rod mags is a place I THINK called United Speedometer or close out in California. I once had my 335 gauges repaired there. As long as they are Stewart Warner I think they can fix or replace your unit. Seems I might have gotten the float level from fella in MN listed on the MM home site for parts. Might even try Agco. Older dealers sometimes have old stock. Tru-Love brothers in IN are like that, or they have other connections linked to them to search. I know in old trucks I have gotten Napa universal units for the sender, and had to combine parts of both to make the tank fittings work. If you don't have a gas line coming out the float link, that is even easier then to use those universal systems.
Thanks for the suggestions! This is not a restoration but a working tractor that we rescued for work around the "homestead". She does manure control, firewood collection, landscaping, etc. I'll check out NAPA and Parts Plus for a universal solution. Thanks again!
John
