Power steering control valve P/N 15A15699
My Big Mo 500 has steering control valve P/N 15A15699. This is the same valve used on later 4-Stars. It is constantly leaking out of the end cover and it leaks whether the engine is running or not. Otherwise the power steering works fine. Before I take it apart to see why it's leaking(bad o-rings?), I thought I'd ask if anyone had any advice, notes, cautions, or WARNINGs on removing, reworking, and reassembling this valve? Thanks!
John
