Josh in MI
I went home for the weekend and did some more "diagnostic" work on the m5 diesel. I filled the tank with enough fuel to get a good supply to the pump. I grabbed a battery and tried to bleed it, nothing again.
I then checked that the fuel was getting to the pump. When I removed the timing cover, I found only one timing mark, with no corresponding mark. By this time it was late and the battery was dead. I was alone and couldn't turn the engine and watch the pump at the same time.
If only one timing mark is visible, does that mean the the pump shaft is probably sheared? I have a bad feeling here.
For those who wanted a way to contact me, well, I am too cheap to pay for long distance and everything is long distance here. You can email me though as I check it often.
