I have all the parts needed to convert my drill to hyd lift but would like to know how you control the planting depth.
Planting depth is now controlled with a lever on each ground lift assembly. Those will be removed now, so do you control depth with stops on the hyd cylinder? I have the original operators manual and it shows several pictures with hyd lift, but make no mention of how to adjust depth.
Thank you.
Thank you.
