MM GVI running again
71ford100
I have been tinkering with a GVI LPG this spring/summer with hopes of getting it to run. Finally today it decided today was the day. After i get a few bugs worked out she will replace the 670 on the springtooth. This is probably the best 425 bucks I ever spent.
What's going on in the North country? I got my G VI out today and started working wheat stubble. Ran a bearing out of the disk so I am down until the end of the week. I need to get my other 3 - G VI's running so I will have more toys to play with. Guess I should get more disks instead so I can keep working when one breaks down. Hope to bring my SP Combine home this weekend.
(quoted from post at 20:10:31 07/22/08) What's going on in the North country? I got my G VI out today and started working wheat stubble. Ran a bearing out of the disk so I am down until the end of the week. I need to get my other 3 - G VI's running so I will have more toys to play with. Guess I should get more disks instead so I can keep working when one breaks down. Hope to bring my SP Combine home this weekend.
Not much harvest is done for us so ita back to the field. I'm battling a claudy a$$ disaster running the spring tooth. In three roungs on the first strip I have lost a wheel on the spring tooth (stupid brother) and had two major oil leaks that are going to require 670 to come back up to the shop and get fixed. So tomorrow I will put a good tire on the GVI change oil and filters and fix a water leak and hopefully be back in the field. The good news is i can now farm at night since I have most of the lights working!
Did ya ever come get that Oliver binder?
Have'nt picked up the Oliver Binder yet. I have the binder, a MM Manure Spreader, several MM plows and a Cockshutt Burr mill to pickup yet. Planning on getting everything this fall. I am going to pick up my SP Combine this weekend. I have to much to do.
