MF 65 Primary Filter
1961MF65
New User
Replaced the primary fuel filter today. After assembly, I had leaks from the canister bolt and the drain plug. Took everything back apart, checked that everything was installed per manual. Reassembled, same problem. Tried tightening both tighter, same results. Took all apart, reassembled with new o-rings, copper washers. Same problem. Any help, or does anyone know if they make a conversion to as screw on type filter?
