Anonymous-0
I put a new fuel shut off valve on my UK 135 and also the line that goes to the primer pump. The parts were MF Heritage line and the fuel line was made in the UK. You'd think it should be just like original. The fitting was slightly oversize for the 1/2 inch wrench that was supposed to fit it. I took a pipeline file and filed my stubby wrench enough that it would go on the fitting. I tightened it as much as I could in the limited space I had to work but I think it still has a slight leak. The brass ferule is supposed to seal against the seat on the valve but if it doesn't, what can you do to stop the leak? Also, has anyone else ever had fittings that were oversize for the proper wrench size? Of course the problems had to be on the hardest fitting to get at. Dave
