Anonymous-0
I put a new primer pump on my UK 135 a couple of years ago and finally got around to fixing some annoying leaks. I'm also putting a new fuel shut off on the bottom of the tank because the old one is stripped (plastic) and won't shut off for changing filters etc. I picked up a couple of "olives" as MF calls them to put in the primer pump. I'm not sure the old pump used them and it didn't leak. The line from the fuel shut off to the inlet on the primer is a plastic line with ferules on it and the line from the pump/sediment bowl back to the tank is a steel line. Is this normal? It looks like the ferules seat against the inside of the fuel shut off and primer pump without the rubber olives but I'm not sure. Maybe some of you MF experts can help me out? Also, it looks like the aluminum fuel shut off just threads into the tank without any kind of sealer. Is this correct? Thanks in advance. Dave
