TACHOMETER
Hooked180
09-18-2023 14:58:00
My 180 MF tachometer all of a sudden is not accurate. When it is around 1700 rpm the tach shows 2000 rpms. The needle doesn't stay steady.How do I know if it is the tach or the drive assemble?The tach only has 54 hours on it.
tractorsam
09-19-2023 01:29:06
 Re: TACHOMETER in reply to Hooked180, 09-18-2023 14:58:00
If the needle is jumping a lot I would suspect the cable is binding, maybe try some lighter lube that can run down the cable.
Dieseltech
09-18-2023 15:06:03
I'd suspect the tach, the gear drive on the alt/gen rear will probably break/quit completely and stop turning the cable instead of jumping around like that. Is the cable well lubed?
Hooked180
09-18-2023 15:31:15
 Re: TACHOMETER in reply to Dieseltech, 09-18-2023 15:06:03
I put some grease on the on the drive end but didn't help.
