Company Logo (800) 853-2651 Shop Now
Approximate weight of a Massey Harris 444 head
FarmerHR
05-25-2023 21:09:08
Have to remove the head off our Massey Harris 444 gas tractor.
Does anyone have an idea of what the approximate weight of the head is ?
Want to make sure I have the proper stuff to do it properly.
Many thanks for any healp you can give me.
FarmerHR
05-28-2023 23:09:38
 Re: Approximate weight of a Massey Harris 444 head in reply to FarmerHR, 05-25-2023 21:09:08
Thank you for your replies. They were a great help to me.
Looking at the head on the tractor it is quite massive. It is one of the thickest heads that I have worked on.
Unfortunatly the tractor is is a field where I am not able to use my engine hoist etc.
Once again, Many Tanks !
MHPull44
05-26-2023 12:49:42
I use rocker stand bolts and a spreader bar made of box tubing with an eyelet. Lift straight off with cherry picker. I move the engines whole that way as well, but it works for just picking off the head and gently setting back on.
Dieseltech
05-26-2023 04:16:52
I'd guess 80-100 LB, that head ain't light..
Jim.ME
05-26-2023 03:58:42
I would expect it to be in the 80 pound range.
rustred
05-25-2023 21:44:44
U should be able to lift 40 lbs.
