Massey Ferguson 35 with perkins diesel serial tag missing so don't know year, red with gray belly. Problem is that while driving the tractor the other day power steering fluid started coming out the steering column--a bunch. I pulled the column off above the valve and replaced that seal and O ring, put it back together---same problem. any help would be appreciated. when I took the column off there was a seal in the top of the column as well as in the bottom, parts book shows only one in the bottom which is all I put back. I have only had the tractor a short time.
Thanks, John
Thanks, John
