Stan Coryell
My 202 steering valve is leaking oil out of the top (steering shaft). It's leaking enough that it needs to be addressed. I understand the spool may be shot, but the leaking started suddenly. It steers easily. I'm using ISO 46 hydraulic fluid, it didn't have ATF in it when I bought it a year ago. When I tried to switch it to ATF, the steering got lumpy. I switched back to ISO 46 and it's been fine for the last 9 months.
Yesterday was the first cool day that we've had, that's when the leaking started. I am wondering what the ball checks do. They are spring loaded. If a spring was bad and the fluid thick (making the check lazy) could that cause the leaking?
It looks like a bit of work to pull the steering box. It would be a lot easier without loader on. The engine block is still leaking coolant into the oil. I would like to try make it until March (after snow) before getting into the motor. It won't get used unless it snows.
Should I pull the steering box and see if it's repairable, or should I leave it until I do the motor? If anyone has been inside the steering box or had one out, I have a few specific questions.
Thanks,
Stan Coryell
Mickleton, NJ
Thanks,
Stan Coryell
Mickleton, NJ
