Massey 165 Hydraulic Issues
Belleek
New User
Gday,
I am new to the site as a member but have read the forums here for a few years and found you all very helpful.
I do have a problem now that I cannot figure out and was hoping someone could provide some help.
I have a Massey 165 with loader, multi-power, diesel, unsure of the year, no serial number can be found. Last winter while blowing snow I lost boom functions. Boom functions are only lost when weight of blower or any implement etc. is lifted. At times it does not seem to have the power to lift the blower as well, struggles a bit.
There is a 3 spool valve bank located directly on the housing under the operators right thigh which controls boom functions and 3 point lift. I am mentioning this because I have never seen this on other 165's. Wet ends usually are an aftermarket add on and my setup appears to be a Massey option. However all of this is based on my very narrow/limited experience!
There was a bit of water in the THD fluid, it has been flushed and no change.
Help Please.
Drain the fluid and replace the hyd strainer and fluid see if that helps. some strainers can be cleaned, if it has high a micron rated strainer replace it I learned the hard about trying to clean one of those.
THey came from Massy but were installed at the dealer. Are you sure you have the
remote controls in the right position? Even having the three point lift controls
wrong will stop the remotes. I grew up with a 65 and a 165D,I own a Super 90 and
I have to relearn it every time I get it out of the shed.
