Massey ferguson 175 with G206 Continental
kgdog15
New User
Hey guys ......i have a massey 175 with the g206 4 cyl continental engine ....It has a tsx-898 carb ,,,,,Will only run with the choke out ,,,and not very good at that ,,,,,,,,Its not the correct carb ...from what i found fits a JD CRAWLER 461 ............Where did you find the Marvel schabler carb # tsx839 at ?
I LOoked on agco mf parts book and lists an 506003m92 but doesnt give a Marvel # ,,,,,tHANKS kEVIN
Has a 2 11/16 bolt mounting spacing
i found this on an older posting
Marvel-Schebler Carburetors Used on Ferguson & Early Massey Ferguson Tractors:
TSX361A TE-20, TO-20
TSX458 TO-30
TSX683 TO-35, F-40, MF-35, MH-50, MF-50, MF-135, Industrial Workbull 202, 204 & MF-2135
TSX882 MF-135, 150, Industrial 2135, 2200 & 2500
TSX695 MF-65
TSX884 MF-165 & 3165
TSX415 MF-85, 88,
TSX839 MF-175 & 180
The TSX361A, TSX458, TSX683, TSX882 are the same size as the 9N, 2N, 8N carburetors and many of the parts are interchangeable.
Carter carburetors were also used on the TO-20, TO-30, TO-35, F-40, MH-50, MF-50, Workbull 202 & 204
The TSX695, TSX884, TSX415 and TSX839 are larger bodied carburetors. Zenith carburetors were used on the MF-135, Industrial 20,Industrial 40, Industrial 2200
This information is from the MF Dealer Parts Sales Guide, Remanufactured Parts section. There might be more numbers in the parts books for the individual models.
Is the 175 a tractor you have had for a while or one you recently got? If you have had it for a time, did it run right in the past? Has it been setting an extended time prior to this?
On the Carbs Unlimited site their cross-reference list shows the 506003M92 as a TSX 893.
Never heard of a John Deere 461 crawler and there is not one in the JD parts catalogs.
This post was edited by Jim.ME on 10/05/2022 at 04:36 pm.
(quoted from post at 16:30:41 10/05/22) Is the 175 a tractor you have had for a while or one you recently got? If you have had it for a time, did it run right in the past? Has it been setting an extended time prior to this?
Its the neighbors tractor ...he has owned it for 5 years ....ran good for a spell then it acts up ,,,,,its a demon inside .....rebuilt engine supposedly ,,,,guy they bought it from said he had to use 2 different carb kits ,,,,,,,,,seems to be a "type c" carb idle and high speed adjustable
https://www.carburetion.com/CarbNumber.asp?Number=TSX-898
I think they have an error in their info. Some JD350 crawlers used the TSX 898. There is no JD 461 crawler.
Has the basic check of how much fuel flows from the carb bowl drain in two minutes by catching it in a container been done? While it many not be the right carb and performance might not be the best it sounds like there are other issues, like restricted fuel or crud plugging ports in the carb, for a couple possibilities.
