MF3165: Help determining what type of clutch to buy
The tractor is a MF3165 Utility with Dual Clutch. I believe it has the manual shuttle transmission. There are three separate transmission levers: forward/reverse, high/low, and 1-2-3-4.
The clutch needs to be replaced. I found a mobile mechanic who can do it. He would like me to order the parts and have them ready so he can do the repair in a single trip.
I'm not sure which clutch kit to order. There are several variations listed for the MF3165.
Clutch hub diameter: 1-1/8 or 1-5/8
Clutch splines: regular or fine
Spring type: heavy or medium
Is there a standard clutch assembly for the MF3165? (The service manual states there are different types.)
Is there a way to determine the clutch type by looking through the inspection plate underneath the clutch?
Or will it require splitting the tractor?
Thank you for your help!
If you give your serial # to the place you want to buy from they should be able to look up what you will need I would think.
The parts book shows to use part number 512356M91 (with disk 1753753M92, and disk 516091M91)
This post was edited by ptfarmer on 09/17/2022 at 10:00 am.
