Hello everyone, nice to meet you.... I'm a long time follower, and this is my first post.
Just recently had a problem this past winter. My fuel filters froze solid. While trying to snowblow, the engine died.
I ended up leaving until spring and used my side by side to finish snow removal duties.
I changed the fuel filters, used wix brand and made sure the rubber seal was placed in the ridge on the tractor and not on the filters.
Primed like crazy and was able to get it partially running using starting fluid to help start. There were leaks everywhere. I ended up getting a gasket kit.
Installed the gasket kit, but can't get it to run on its own. It won't even start on its own either.
I have tried getting it to start by towing. This works, but once the tow is over it will not run on its own.
When bleeding there is diesel at each of the injectors as well.
Any ideas would be greatly appreciated.....
