R Mulvaney
New User
Hello All, I have a 1969 MF-135 Multipower. I have owned it for about 10 years. Since I've owned the tractor, upon start up, the PTO would turn with power regardless of PTO lever position (ground, neutral, engine). That had never been a big issue for me because I only used the tractor for towing things. I just started using the tractor on a 60" brush cutter. My issue started with the hydraulic three point hitch didn't want to raise when the tractor got warm. After some more use, now the PTO will stop under load regardless of lever position. The multipower has also stopped working. The multipower is stuck in low, which is not good because it will free wheel down hill. I have flushed the hydraulic oil and wanted to change the filter. After watching you-tube I took of the PTO lever cover plate and found what I believe to be the multipower hydraulic pump over the filter. What is the procedure for filter change on this unit? Do I need to remove the lift cover?
