I have a Continental gas 135 with a generator, and I have been having some intermittent charging issues. I've gone through the wiring and cleaned some bad connections up, and tested the generator and everything seems to be in order, most of the time. I don't have the L hooked up on the VR as there is a lot of homebrew lights wiring on this, and I wanted to eliminate any of that, and thought that it should still work without it. I've had this tractor for about 10 years, and use it regularly and recently developed this charging issue.
I've been working on this the last few days as I was baling some hay, & ran it with a volt meter hooked up so I could watch the battery voltage as it operated. Periodically, it will just stop charging and sit at the battery's voltage of 12.5V until it begins to charge. I found if I tapped on the voltage regulator, it'd start charging again. So I lightly sanded the points on the relays. No effect.
I'm not real savvy on generator/VR setups. I can't imagine what could make the electromagnet stop pulling the points in, short of a bad connection or ground or something, but like I said, I checked the wiring using an OHM meter, and the VR box seems to be making good contact to the frame, unless there's a better way to ground it than the mounting screws, and tapping it is making the ground better. It's an aftermarket VR I put on a few years ago.
Thanks for any advice. I don't really want to put an alternator on it.
