junkbucket80
New User
Hello, Im new to owning a tractor. I have a MF204 Workbull. It has a torque converter instead of a clutch called the reversomatic. When I bought it the PTO and the 3point didnt work. I replaced a broken pump and now the PTO spins but only when I am moving in forward or reverse. Is this normal? How would I use implements like a post hole digger if the tractor has to move? Does the 3 point lift only work if the PTO is engaged and if I am moving? I cant seem to get that working either.
Thank you
-A severely confused new owner.
Thank you
