My tachometer cable in my MF2244 crawler/loader twisted in half (the interior flex drive) and the outside is very dry rotted. Does anyone know of a replacement? It's 1m long (~39in). So far I've had no luck locating one.
As a side note, the weldment of the tachometer cable passthrough failed, causing a diesel leak (for those that aren't familiar, on this 2244 the tachometer cable passes through a steel tube welded in the dead center of the tank like a tunnel). Mine was a bit gunky, but somehow even though the leak was on the outside of the tank on the front, it managed to make the back of the tank wet as well. I'll chase it with some MIG spots. If your tank is wet, might pay you to have a look around the strap clamps close to the tach cable passthrough.
