Prepare4Disappointment
New User
Howdy, I m new to the tractor world and would appreciate some help with my now torn down engine! I do need a manual and or video about rebuilding it, especially if I should be looking for anything specific for wear or I should replace.
It s a Massey 135 I believe 1960s, Perkins AD3 152, 6 speed - 3 speed, reverse and high/low. Stamping in the block is 152ua 104476d other IDs on block are "e 29 8" and 37111500.
I took the crank and cam to a machine shop and they said the thrust bearing face was worn out on the crank, and while it would work- it wouldn t be right, but they did say the cam looked fine, really no wear or cause to resurface.
What engine rebuild kit with crank do I need?
Do I need to do the head studs?
Does this engine have cam bearings?
What 2 clutches and pressure plate do I need? It had the thin metal shim around the pressure plate - I plan to just clean up the flywheel.
Should I do anything else?
I was just planning to lap the valves, clean everything up, rebuild kit and put it back together with a new oil pump, I m not planning to remove the fuel injection pump or idler gear. I would like this to be an easy project and not a big mess, I appreciate any input, Thanks!
