Okie Haymaker
New User
My injector pump is in serious need of a rebuild. I've researched several forums but still have questions. I've read to remove the cork on the bell housing and line up the timing marks there and I assume the mark under the inspection cover on the pump will line up too at some point. When I get both marks lined up at the same time is it safe then to remove the pump? Or is there a chance I could still have it 180 degrees off? I'm 72 years old and have learned the hard way it's best to ask questions first before you start a project like this. Any help appreciated.
