All,
I find conflicting information on this all over the web. I see that seals are available, but also read that machine shops need to mill the head to accept them?
I've got an issue on #4 cylinder since I bought the machine in 2015, since it doesn't get used all the time I've just dealt with cleaning the plug and rotating it to a different cylinder to prevent oil fouling it. I'd like to put some new valve stem seals in it. I get a lot of oil in #4, enough that it'll coke up the plug and misfire badly.
I've narrowed it down to valve stem seals, compression is good across all cylinders.
Is there a drop-in set that I can just pump the cylinder full of air, or a rope, or whatever to keep the valves in place- compress the spring, pull the keeper, slap it in there and reverse the process for install?
I also see two different kinds, one with the little metal spring in it (the style I'm used to) and another set that appears to just be a rubber bushing of sorts, thoughts on that? Thanks.
This post was edited by shaeff on 08/17/2022 at 05:47 am.
