There are two tubes coming down on left front of 3208 catipilar motor one from top of fuel pump and the other is for priming or get air out, when you pump the primer with valve open fuel runs out one tube should it run out of the tube from on top of the pump? I primed it twice so fuel runs out one tube, the I cranked and had 6 out of 8 injectors tubes loose at injector and cranked fuel run out but not start, I see some say there are more plugs bleeding necessary on pump itself is this correct?
Last time I run it was three years ago did no come up to speed but idled nice.
It has old fuel filters but air passes thru so should be good enough for starting.
