Replacing 44 Special Transmission Input Shaft Oil Seal
waclar
Is this replacement possible by just separating the shaft at the coupling to slide seal over driveshaft or do you need to either slide engine forward or break tractor in two, looks like I only need about an 1/2in more separation. Anyone dealt with this before or have a manual that might list the steps? Help is much appreciated. Thanks
