Dirtrancher
Hello,
I have a Massey Ferguson MF3165 with the AD4.203 Diesel. The tractor was running fine. Then after a shift from reverse into forward, nothing happened when I let off the clutch. It felt like the gear had engaged, but the tractor acted like it was still in neutral (rolled back). I tried different combinations of forward/reverse, high/low, and 1-2-3-4. Still nothing.
The gear levers seem to be working. It feels like it's getting into gear each time. There is a slight grind before engaging (like it normally does). I'm not hearing any other strange noises. I don't think the clutch is slipping because the RPMs don't change when I let off the clutch.
Any ideas where to start troubleshooting? Any help would be much appreciated.
Thank you.
Thank you.
