MF 135 Fluid Loss / Fluid Gain.
sixbales
Tractor: 1965 135 MF, gas engine.
Owner reports his 135 is leaking P/Steering fluid from reservoir into the differential housing and overfilling fluid level. No external leaks at all. How does
this happen??
Don't see how, unless the housing is cracked somewhere. I have seen the top support plate area broken on one tractor at the dealer I worked for years ago when Bubba decided to jack up the pump relief valve. The steering box didn't like the extra pressure..
Thanks Dieseltech and Stan. I couldn't see how this could happen, so I decided to ask you guys!
