Axell
- Location
- Scandinavia
I have a 35x that I am not sure if the hydraulic is working properly. It has a double valve under the seat which has a quick coupler and a fel was once attached to the other valve. I got myself a sickle mower. A more modern one with hydraulic lifting of the bar.
The lift arms works like they should. They can be positioned where you want them. I thought that was the case with the bar too. But it can only go all the way up or down. The quadrant just controls the speed. So not at all like the lift arm do. So if a fel was attached it would do the same which they isnt right. So is the hydraulic broken?
