agdodge4x4
Not sure if there is anything I can do. I have read the manual multiple times and I am doing exactly as it states to operate my ground engaging equipment in draft mode. The issues are that when it is in draft mode, the implement response lever has zero effect on how fast implement moves up and down. The only thing that seems to respond to the employment response control is when you were using it in position control only. Also, once you get the implement lowered for draft use, once it starts to bog down a little bit it raises itself automatically all the way to the top and does not go back down unless you manually force it with the levers. When it is in transport mode for position and the draft control lever is pressed downward, it takes almost a four minute for the implement to go down unless you push the position control down. Either way, the draft does not seem to work as designed. Is there anything I can do to check this thing out or is this something I need to run it to the shop for.
