MF 135 fuel sending unit
garymck
I am replacing the fuel sending unit with the correct one for the gas tank that is 6 inches deep. There are no instructions with the replacement and the rod with the float is too long and can be cut. Anyone gone through this before me? Any advice is appreciated.
I recently installed a VDO 226-007 sender in a MF175 diesel. Here is a link to the installation instructions.
https://static.summitracing.com/global/images/instructions/vdo-226007.pdf
The tank sending unit has to have the ohm range that matches the gauge. Did you confirm the ohm range of the replacement sending unit is correct for your gauge?
