Drew.Styduhar
Hello
I have a 1979/80 Massey 20C. It has a loader. The clutch pivot bushings (and shaft I imagine) are totally shot. I assume the tractor needs split to fix these?
Im in a unique situation where the front axle and basically everything on the engine is already stripped down. The engine and loader frame are supported by blocking Here are my choices as I see it:
1. Finish reassembling the front axle so I can split the tractor by rolling it apart
2. Hook the to engine with my cherry picker, support the trans and separate the engine now.
Anyone been down this road? Advice? It has a ad3.152 perkins, how much does that weigh?
thanks,
Drew
thanks,
Drew
