65 power steering help
Mdmoore
New User
Need help finding 65 massey ferguson tractor power steering gear box bearings. Bearing number 1850526m91 with not fit.i need a 2 3/8 inch outer diameter and 1 1/2 inch inner diameter. It's a 4 cylinder Perkins diesel any help finding these 2 bearings would be greatly appreciated. Thank you.
There are four different steering gear box parts diagrams.
Under STEERING GEAR USED, ALL AGRICULTURAL MODELS
1024477M91 Bearing Assembly
I found the bearing on this sites parts listings, but it indicates it also fits your part number as well and lists it as 2 9/16 diameter.
You are working on the steering box directly under the steering wheel, not the assembly up front behind the grill, correct?
Massey Ferguson 65 Bearing and Cage, Steering
Yes right under the steering wheel. The gear box is pretty simple. I don't know if it has been changed or not. It takes the smaller bearing. 2 9/16 is to big. I saw a post on here that someone a few years ago looking for the same bearings that I am. Now I can't find the post.
If it is the bearing right under the steering wheel I
never found a new one dealers internet etc....
I had a remain of teflon sheet 1 inch thick drilled
outer dimention to have press fit in the steering column
with a hole saw drilled the center to the shaft size inserted
in the column put grease. It was 20 years ago and not loose yet.
HTH Bart
I looked through the MF50 parts diagrams as well and can't find a different bearing part number for the steering box. You may have to find a bearing supply store and see if they can match something up with your old bearing. I have used Kaman Bearing to get bearings and seals.
Thanks Bart it's the 2 worm gear bearings one is in the top of the gear box and the other one is in the bottom of gear box. Both bearings are the same.
