135 fuel lift pump
CRezrider
New User
My lift pump is leaking and I thought I'd just replace it but I'm having trouble identifying the correct pump. My engine serial number is 152UA190515D. The pumps I see listed appear to be for serial numbers later than this. I think my tractor is a 1970 model. Any help is appreciated.
Yes, I did try snugging the screws, but it still leaks. Mine does not have the glass bowl, as some appear to, and has the manual pump handle on the front side of the pump instead of the rear side as most of the units pictured do. I wonder if it could have been re-fitted with a newer pump at some point. Thanks again for any help or advise.
(quoted from post at 10:34:27 11/22/21) Yes, I did try snugging the screws, but it still leaks. Mine does not have the glass bowl, as some appear to, and has the manual pump handle on the front side of the pump instead of the rear side as most of the units pictured do. I wonder if it could have been re-fitted with a newer pump at some point. Thanks again for any help or advise.
The 135 parts book shows 3 different pumps, two with bowls and one without a bowl. do a search using the Massey Ferguson part number of the one like yours. Hopefully this link to the page of fuel transfer pumps works correctly for you.
https://parts.agcocorp.com/en_US/ap...;tocGuid=635689ec-997a-7b78-d197-eacd77acce5e
