I am putting in a new clutch and figured I would go ahead and change the seals on the input shaft as well as the PTO shaft of the transmission. I don't have multipower, but I believe the tractor did at one point. I ordered 195 501M1 and 195 503 M1, but those are the wrong ones. I am confused as to what seals I need, my input doesn't look like anything in the diagram of the parts book.
I have got it down to these part numbers:
Input seal- 192 329M2, 886 673M1, or 860 867M3
PTO Seal- 883 935M3
Serial # is 9A 165 101
Does anyone know which input seal is correct? And if I have the correct PTO shaft seal?
Should there also be a gasket between the input shaft retainer and the transmission housing? There was not one there when I took it off....
I also noticed that there were none of the sealing rings on the input drive shaft. Its definitely been messed with by someone before me. And I was under the impression that the multipower would show have a clutch pack immediately behind the input shaft, as you can see, there is a black gear visible in the picture.
See pics for additional info, let me know of any more info that could help.
PTO Seal- 883 935M3
