Hello all
I have a Massey pony I found in a barn. I replaced the points, condenser, coil, spark plugs, wires, harness and battery. Gave it a cheap little paint job as well. I had spark - but wouldnt start bc the carb was plugged. Cleaned the carb, put it back on and now Im not getting any spark. Its got to be something really simple but I have no idea what any help?
If it helps when its turning over it seems to be sucking air out of the exhaust instead blowing it out. Unsure why - although its probably a different issue. Its a positive ground but I reversed the polarity and it turns the same way anyways.
Im at a loss - cant be that difficult - there must be something small Im missing.
Heres a pic of the setup if it helps. Thanks a lot! Paul
