Exhaust pipe & muffler 2 bolt flange for MF TO35
W. Heller
New User
Does anyone know where I can purchase an Massey Ferguson TO35 Exhaust pipe and muffler assembly with 2 bolt flange to attach it to the manifold? It mounts in the horizontal position. I find plenty of 3 bolt flange ones, but no 2 bolt. Is there any way to adapt something? The tractor is a 1955 TO35 S/N 149806.
I believe your manifold has been changed. Check whether a to30 exhaust is a 2 bolt. All 35's are 3 bolt.
(quoted from post at 09:57:00 09/06/21) I believe your manifold has been changed. Check whether a to30 exhaust is a 2 bolt. All 35's are 3 bolt.
You are correct it is a 3 bolt. Another question I have is do you know what the threads are on the studs in the manifold? I may have to replace them at some point. The one in the back toward the block is stripped. Looks the like threads rusted away. The nuts on the studs are a strange size. The only size socket I found that would come close to fitting them is a 17mm. It was a little loose but did work. Things are back together and doe not seem to leak. (knock on wood) Thanks again.
I just changed a muffler on a Z134 engine off a MF202 workbull (same engine on the to35) and it was a 3 bolt.
Even with heating the manifold red hot the bolt still broke in the manifold, had to drill them out and retap.
You can always buy the standard 3 bolt flange muffle rand modify it with another piece of metal welded to it to match up to your 2 bolt setup.
