Mf 202 backhoe with 102 loader pump leaking
Billmo
New User
My front pump is a Cessna and I cant find a rebuild kit. Will the pump off of this site be an exact replacement? Same pressure at the same RPM etc.?
Thanks
(quoted from post at 17:06:12 09/04/21) My front pump is a Cessna and I cant find a rebuild kit. Will the pump off of this site be an exact replacement? Same pressure at the same RPM etc.?
Thanks
Cessna made a number of pumps and it would be hard to tell if yours is even the original one. My thoughts are you need to measure your pump and see if it matches the info for the one on this site. You may need some different fittings, if the shaft and mounting dimensions match yours.
If you are looking at the 14 GPM pump it should work a loader. If yours has a backhoe as well you may want a pump with more GPM. Pressure is controlled by a relief valve in the loader or backhoe control valve, not in the pump, it should have the same pressure it had before. The volume of the pump will dictate the speed of operation at any given engine speed.
Someone may be along who has used the YT pump to replace one like yours.
Thanks Jim I do have the BH and I have the # off the Cessna
pump but I didnt find anything online for it but a vintage repair
kit that was sold
You have the numbers off it, Have you call an actual pump shop or two, not just looking on line? Sometimes they have other sources, or can mix and match for old pumps.
I would try seal lube by New Tech available online. It has repaired many old seals for me. Just add it to the oil, worth a try.
