1233 smoking
Reliable225
New User
Hoping some one can steer me in right direction. Just got tractor and is blowing white smoke bad and running a little rough. Smoke has strong diesel smell. Replaced injectors, did not help. Checked and slightly adjusted valves.Did compression check, #1 310, #2 318, #3 300. This was on cold engine . Could it be injection pump timing?
(quoted from post at 01:54:01 07/21/20) Hoping some one can steer me in right direction. Just got tractor and is blowing white smoke bad and running a little rough. Smoke has strong diesel smell. Replaced injectors, did not help. Checked and slightly adjusted valves.Did compression check, #1 310, #2 318, #3 300. This was on cold engine . Could it be injection pump timing?
Did you figure out the problem - I am having something similar
