rmissildine
Hello all. Back in June I posted a problem about my pto clutch slipping. Thanks to DieselTech, it was determined to be a weak Belleville spring. I replaced the clutch assembly, but due to waiting on ordered parts from all over to make other repairs while the fuel tank was off, It was well over a month before I was able to fire up the tractor to check out the new clutch installation. Without a mower on it, the pto engaged without any problems and the drive clutch worked great. I decided to check out the pto with mower attached a couple of days ago. The pto clutch wouldn't disengage. I checked the clearance on the pto clutch release bolts and it was a bit excessive, over .090, so I adjusted it to 0.80. Still wouldn't disengage. This morning, I got the wife to push down on the clutch pedal so I could observe what was happening from underneath. I could see the bolts being engaged and movement in the clutch disc, but seems to be sticking on the back side, if that makes sense. So I ran the adjustment down to around .025. Clutch still won't disengage.
Anyone ever ran into this problem before, if so, what is fix for this, if there is one.
Thanks in advance,
Roger
Thanks in advance,
Roger
