Hello, I have a Massey Ferguson 265 that is giving me fuel problems - I serviced the fuel system & changed the fuel filter & bled the air out of the system and started the tractor and everything was normal ( ran fine ) My brother started bush hogging and made several passes and all of a sudden the tractor lost power and went down to 1/3 throttle and then idle and it just cuts off.
It will start back up and it goes to 1/3 throttle or less and will not hardly pull out of its own tracks. I suspect that the lift pump may be bad but not sure and wanted someone else's opinion - I checked fuel flow from the fuel tank to the lift pump and the fuel flow is good there. It just acts like its starving for fuel.
Thanks for your help, Clary McGee :?:
