Lost My key to MF 1964 35 deluxe
bcraig2N
I lost my Key to my MF 35 deluxe Gas Burner(Cant remember where I put it,Bad memory) and I have found replacement keys on eBay but don't know which one to buy.
I see that they make a split type of Key and a solid key.
But with my Bad memory I cant even remember what the key looks like !
Is it a split type or a solid type ?
Thanks
I only have TO-35s but they are the two-forked/split key design. It's pretty common so if you grab an ebay/amazon key it's likely to fit.
Unless someone along the line bought a random starter key switch then you could have anything.
The OEM ones all used sit keys, as far as I know. But aftermarket ones use a different key. Yours could be either one.
Looking in the place where the key goes should tell you what kind you need.
