I am having problems with being unable to change the gear shift selector.
The tractor is a Massey 35 Deluxe gas burner 4 cyl with Hi Lo 1964 model.
Last year I shifted to fast from Low 2nd if I remember right to reverse while tractor was just barely moving while bushhogging .
Tractor Gear shift the hung in reverse with shifter unable to be moved to a different position.
I remembered reading a post that said that the trans oil cap could be taken off and then a long screwdriver could be used to stick down into the gears and the problem solved.
I tried this and could get the tractor in another gear but still would not be able to get the tractor in another gear unless I used the screwdriver again any time I want to change gears again.
It sure gets old having to get on and off the tractor and stick a screwdriver in there every time I want to change gears !!
Could someone tell me or show me a picture of how to properly use the screw driver to solve this issue.
I sure would appreciate the info and a picture !
Thanks
Thanks
