I have a perkins ad4.203 in a 50a that I need to rebuild because of a #1 rod bearing spuns. I have rebuilt many gas engines from cars and equipment put never a diesel or a perkins are there any items that I need to consider? The crank and rod are out for machining now. I plan to get an engine kit and install new liners, pistons, rings and bearings. Also a new oil pump. I will check block and head for flatness (book says .003) I also plan to dye check the head. I am not planning to valve work to the head as it was running fine and everything looks good. This will also be a hobby machine that doesn't see a lot of action and the head can be removed in tractor if needed.
I really want to avoid splitting this thing again in the future. So additionally I plan to replace the input seal on instant reverse.
Anything else I should be considering?
