Missing power jet in marvel carb (type b) tsx 388 of my
martin rock
New User
Hi all, I just dismantled my carb for cleaning since it was leaking when engine off. I noticed that there was no power jet in it. Should i try to find one for it or just leave it as is?
Thanks This is the jet below the nozzle.
Can't answer your power jet question (if the tractor is working without it you may not need it);
But if your tractor is leaking fuel when off ... that's common. You need to turn the fuel off at the bowl using the wheel or 'T' shutoff every time you are not using the tractor or else your tank will empty. Then you need to remember to open it when you go to start the tractor.
I had a MS TSX 458 on my TO-30. It was not tapped for a separate power jet. The needle valve went into a drilled passage. Maybe yours is the same.
