3pt Stabilizer bar for Massey 35
Guys I need a stabilizer bar (or 2) for my 3pt arms. Currently just swinging back and forth. I bought the solid stabilizer arm from tractor supply but it seemed to want to bind. Perhaps I should have moved the axle side mount around. Regardless if you have one to recommend please let me know - maybe even a telescopic one.
Is it the right length for your machine, or is it just tight from being new?
Until I got my 135, I never thought about sway bar length being different between brands. My 135 takes a longer bar than our 8n's.
I got a pair shipped in from this site, and they're fine. They're tight to get on one of the implements, but that could be that they're so new the holes aren't egged out yet, or the implement might just be off enough to make it irritating to use both bars. (just use 1 on that piece currently)
I also found the PO of the 135 had the sway bar mounting pin under the axle in the wrong hole of the mount. Those need to be in line with the lower lift arm pivot points.
